UART Serial port enabled = Dont boot
Hi everyone from Argentina!
Sorry for me english.
I need open the UART Serial port, disabled by default on RPI3 Volumio. Is for use an LCD 16x2 display : sparkfun.com/products/9395
When i try to open the “enable_uart=1” on /boot/config.txt, after reboot, the system dont boot.
There is a bug with Serial port?
Regards and thank you!
I’ve got the same display and could not get it to work with volumio.
Does anyone have any suggestions?
github.com/raspberrypi/firmware/issues/798
You need to remove the line kgdboc=ttyS0,115200 from cmdline.txt in /boot/. It turns off debugging over serial.
My guess it’s leftover from devs debugging over serial, let’s hope it gets removed in future versions.
