First of all, thank you for the great work!
I’ve found two things with the Compulab Utilite port:
- I can’t connect to wireless with v1.3 (but I can with v1.1)
- Fuse is not installed, so I have no access to USB hard drives formatted in NTFS or FAT both for v1.1 and v1.3
I was able to workaround the 2nd one by attaching the drive to my router, but the first one was just impossible for v1.3, as it would complain about broken python when I tried to install wicd-curses.
Can you look into these issues? It would make a great product even better!
Thank you!
Gustavo
