Shumer
March 27, 2023, 11:42am
1
Good afternoon, I would like to be able to turn off the red LED in the future through the settings menu.Also, when connected to a TV, I would like to control using a Bluetooth aero remote control.
I guess there is a question in this?
Added support for exellent bluetooth remote G20BTS PRO (available on Aliexpress) to my RPI4 based Volumio. Now both playing commands and gyro mouse on screen with touchscreen plugin work perfectly
Here are steps
Enter your RPI4 via ssh and pair your remote with bluetoothctl (comes with Volumio)
Copy file g20.py (below) to /home/volumio and give execution permission: chmod +x g20.py
Under sudo create file /lib/systemd/system/g20.service (below)
sudo systemctl enable g20
sudo systemctl start g…
Shumer
March 27, 2023, 1:06pm
3
I have a ready-made solution, volumio rivo. How to connect to it?
Unable to answer, don’t have a Rivo. I expect in the same way.
@DED ?
