Hello friends,
For the more experienced there is a way to configure the software to improve performance and audio quality.
Thank you.
Hello friends,
Thank you.
Hi
Considering your setup is a quality one adapted to your listening room
Objectively
60% of bad sounding system is room effect
40% is jitter and electric perturbation
I use Balbuze FusionDsp for basic software room correction (parametric equalizer, LR delay for instance). Full dirac room correction would be good to consider also.
Work on your cables, power supply and ethernet for the rest
Anything else like bitperfect settings, music shield, resampling …etc are for me subject to caution… but I won’t denigrate them
thank you!
where can I find a tutorial for this: I use Balbuze FusionDsp for basic software room correction (parametric EQ, LR delay for example)
Ty
Beware, you will have to do and understand things harder than google search FusionDsp How-to
Good luck
