Tunein plugin won’t install
Good morning
I have just spun up my first Volumio install in RASPI zero and I am very impressed so far but have hit a bit of an issue. I think there is a broken link in the install function of the plugins for tunein radio.
The install hangs and stays showing 10% and no error message.
The plugin link shown by clicking on show details is volumio.github.io/volumio-plugin … _radio.zip
However the link is broken
So any tips resolving this ? I could ssh but there appears to be a bug with the UI which could do with fixing. So any advice greatfully received.
Have a look at the system logs to see what happens during the installation volumio.github.io/docs/User_Man … oting.html
Could you explain what you mean here please?
Sorry. That message was confusing. What I meant to say was I could ssh into the pi and manually install the plugin but I wanted to report what looks like a bug with installing the plugin via the browser
got same problem also.
installation stuck at 10% all other plug ins downloading without problems. running version 2.657
I also cannot install autoplay or autostart - sucessfully installed Spotify plugin though…
the same problem, stops at 10%.
We’ve removed the Tune In plugin since it’s now integrated directly into Volumio.
okay thanks for the info.
Hi Michelangelo,
Great, thank you.
One question to make it clear to everybody like me…
Does the normal Radio Station search now additionally use tunein as source ?
The reason why i’m asking is that there is no new version of Volumio and i do not see anything that shows me tunein is now integrated.
P.S. Please check your PM regarding the old versions…
Saluti distinti
Josef
Hi Michelangelo,
Just checked back with v2.657 and experimental v2.659:
One of my favourite radio stations located in Costa Rica (Radio Dos) is still available if i hack back with the (well backuped tunein plugin) - but not if i use the common search function…
When will the integrated TuneIn feature be available, and ---- will it still be available for free ?
Best Regards
Josef
It’s already available and of course for free.
Please explain better what you can’t find and I’ll try to help
Hi Michelangelo,
I tried searching for “Radio Dos” in the search field on the Internet Radio page. There is no hit.
What i am doing wrong ?
Best Regards
Josef
Instead, before with the Tunein plugin you were getting more results?
Yes - with the tunein plugin i get offered a couple of radio stations - one of them is the one from Costa Rica that i am searching for
Seeing the same problem here, for example searching for the string
radio punto zero tre venezia
should show one result from tunein.com
tunein.com/search/?query=radio% … %20venezia
I have two rbpi 3b+ both running volumio 2.692, one still has the tunein
plugin version 1.1.0 installed. Here the tunein addon finds the station
using the search phrase mentioned above, while the other rbpi, having
only the internet radio plugin, does not find it, the search result is empty.
While playing around and comparing search results from tunein.com
(the tunein addon finds the same results compared to the website)
I would suggest that search phrases containing spaces might be
problematic for the internet radio plugin:
Searching only for “punto” finds “Radio Punto Zero Tre Venezia”…
HTH
PS: Reported on github: github.com/volumio/Volumio2/pul … -572905239
Please test todays update, it includes
github.com/volumio/Volumio2/com … 2aa4d5973a
which hopefully will fix the problem.
Version 2.729 includes more. Improvement for web radio
  • alphabetical sorting for search
  • search for radio with multiple space in name
  • result gives only webradio
Nie wszystkie radia są w pluginie TuneIn w Volumio. Nie można znaleźć np. Rockserwis.FM
[Mod]
Translated by google:
Not all radios are in the TuneIn plugin in Volumio. Rockserwis.FM, for example, could not be found
I vastäh koa Wort
I don‘t understand any word
Just added the translation.
