I have been using the pi 3 with a little OLED (no local monitor) all worked well. I purchased a little 8 inch monitor (16:10) and updated volumio to the latest update.
I can interface with the pi via webUI, and it works perfectly, but all I see on my monitor is the
Welcome to Volumio
webUI available…bla bla
with vinceserver Login
How do i get the full display to work, and not as a terminal interface?
install the plugin touch_display
Thanks…I tried to install the plugin, but it didn’t want to install got the following:
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/touch_display/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/touch_display/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Hit:1 https://deb.nodesource.com/node_14.x buster InRelease
Hit:2 Index of /raspbian buster InRelease
Hit:3 Index of /debian buster InRelease
Reading package lists…
Running apt-get -y install failed
Plugin failed to install!
Cleaning up…
Removing dependencies
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
Enabling login prompt
Done
Removing temporary directory /tmp/touch_display-5zVN1sh6Yo
OK got it all working.
Did a Factory Reset, then tried to install the Touch Display plugin…it did a ton of updates, then installed the plugin.
All working great.
thanks all
