Hello everybody,
i installed Volumio on a Raspberry Pi,
the Rasp is connected to my local network thru Ethernet, and play songs from my NAS Synology which is on the same network.
The sound is send to my AudioGD Dac thru USB output of the Rasp.
But audio listening is corrupted (like digital distorsion), even with webradios.
do you think it is…
bad cohabitation between USB and Ethernet on the Rasp
bad setting on Volumio (i use “audiogd” as output, and tried to increase buffer size but is has no effect)
other ?
Thanks in advance
