Hi all, I tried to install the Spotify plugin but there was an error. I now can’t uninstall it either.
Is there somewhere I can go to see the log and find out why it didn’t work? Or can I install it manually? If so how do I find out the proper URL to install it from?
Hi Balbuze, thanks for the tip. I tried that, and I get the same problem.
A few things
I don’t think it’s the SD card as I only just bought it and haven’t done very with it - it’s basically a fresh install of volumio, and I’m not having any other errors.
