I have similar problems with both Pi3b+ and the tinkerboard. In setings, library stored in NAS shows network drive mounted but no album and track count indicated Update or rescan not responsive. If lucky the library appears at home menu but only partial contents and those can play! Then the library disappears again. Now have to resort to going to home menu media servers and find the nas then they are all there and play fine. The Pi3B+ also could not recognize an USB hdd drive which it was able to recognize before the update.
PC version in same update runs in NUC both internal ssd and nas no problem at all!
This is the log for the Pi3 B+ logs.volumio.org/volumio/hOaKz1m.html
The previous log was for the Tinkerboard
The X86 update for NUC was fine in terms of the problems experienced in the pi3 and tinkerboard.
Thanks for the help.
Just tried 2.713 on Pi3 B+ better but scanning of NAS library not possible to go over 23x albums where I have over 2000 albums and the strange thing is after 23x albums then it will stop and show exactly 127 albums every time. Library shows the same 127 albums. Here’s the log: logs.volumio.org/volumio/1jp5fE3.html
Will try my luck with the Tinkerboard now. Thanks!
Thanks! Tinkerboard scanning of NAS albums looks good now. Same count as the no problem pc x86/x64 2.712.
However, the pi3 b+, followed your instruction to save playback option and retry… no success. Did a factory reset, saved the playback options first then did the scanning… stopped at 31x albums then this time showed zero albums… here’s the log: logs.volumio.org/volumio/ESumhxa.html
2.713 seems to have issues with media scanning, too. My USB drive is not detected, and when detected it just scans a few folders and that’s it. It was working fine with the last January build.
