i’m trying to beam volumio from the micro sdcard to the onboard flash.
Should work with pressing the bootswitch button while powering up, but doesn’t.
Have i blundered?
Have i blundered?
Problem solved with new sd card.
How it goes? Are you satisfied, any feedbacks?
Beagleboard works perfectly well on the music side, as I have written in the "first time troubleshoot " section there have been no distortion issues at any samplerate, music format or dac i’ve used so far.
Nevertheless: I usually don’t switch it off, but when I return in the morning, it’s unreacheable and i have to restart it by plugging out/in. Well, we’ll see.
For the hardware: if you have a stationary environment with Lan and Nas you dont need more than one usb slot; besides i like the 5v plug better than the miniusb that raspberry uses for power input. If you want to switch between different psu it s much less fiddeling.
