tracks cutting out near end of song
Hi
Been a happy Boss Player (inc dac) for a week now, no problems at all until I updated to the latest release tonight.
Since the update every track I play cuts out for one second about 10 seconds before the end of every track.
I thought it may be an issue with pre buffering the next track but I’ve changed setting and nothing fixes it.
Hardware is;
Allo boss player with dac.
Usb harddrive
WiFi ( tried hotspot only and same glitch) for remote control via app
All self ripped FLAC files in 16/44.1
Any ideas what’s going on?
Nobody can help here?
I’m guessing nobody has any help to give or doesn’t want to admit fault with software?
Maybe time to try runeaudio or similar.
Is it possible you use a usb-harddrive without own psu or an active hub?
THanks for the suggestions, I’ve tried my hdd powered by the pi and powered by a desperate usb hub and still nothing has helped, odd thing is that it doesn’t happen on every track, maybe it’ll do it three tracks in a row maybe 5 sometimes it’ll be fine for a few tracks then it’ll be back again?!
Most confusing and very hard to pin down the fault due to its random actions.
