Hello community, my problem is that the track displays of the tracks are often not synchronized on TIDAL streams. What can be the reason for this? If I then manually “fast-forward” a track, it works.
Here may be the solution to the problem: I rewrote the current Volumio image to the SD card and set up Volumio again. Now the track title display works perfectly.
