Touchscreen stopped working, error: ENOENT: no such file or directory, stat '/tmp/.X11-unix/X'
So, yesterday, after my Pi4 restart, the touchscreen stopped displaying volumio UI.
I already created a new installation (flashed) and installed Touch Display plugin (1.3.0) but still no UI is visible.
Moreover, when I try to change touch display plugin settings, the following error is displayed:
“error: ENOENT: no such file or directory, stat ‘/tmp/.X11-unix/X’”
Can anyone kindly help me?
Thanks,
Marcin
Hi @marcin_stawny,
try uninstalling the Touch Display plugin and re-installing it.
If that should not help please connect to Volumio via SSH and post the result of
systemctl status -l volumio-kiosk.service
BTW: Did you install any other software than the Touch Display plugin? If so, which?
Thank you gvolt, oddly enough after reinstalling all seems to work fine.
Marcin
Good it’s working again! :grinning:
greetings to all
sorry for my bad english.
I do it with google translate
The problem is the touch display plugin. It always worked well until the volumio 3 update, but since volumio 3 nothing works anymore. sch many times all completely reinstalled, according to instructions and tips in this forum. Unfortunately nothing helped. The message that comes up is always an error connecting to the Xserver.
error: touch_display: Xserver unix domain socket cannot be determined. info: CALLMETHOD: system_controller system enableLiveLog true info: CoreCommandRouter::executeOnPlugin: system , enableLiveLog info: Launching a new LiveLog session error: touch_display: Xserver unix domain socket cannot be determined. 213.144.138.218 local addr 192.168.1.239 → error: touch_display: Xserver unix domain socket cannot be determined.
thank you very much for your help
  1. What is your Volumio version?
  2. What is the version of the Touch Display plugin?
  3. What are the brand and exact model name of your screen?
Volumio 3.233 (3.249) update no posible.
Plugin 3.3.1 (3.3.2 , 3.3.3 , 3.3.4 , 3.3.5 not installable, error)
RASPBERRY PI 7TD Raspberry Pi Shield - Display LCD-Touch, 7", 800x480 Pixel
With the greatest probability a download error occured when you installed 3.3.1 of the plugin. Therefore a software package the plugin requires is missing which in turn causes the error message “Error connecting to xserver”.
The fact that installing the mentioned newer versions of the plugin failed confirms, that you encounter download problems: Unlike 3.3.1stable all newer (beta) versions detect download errors and cancel the installation of the plugin if such an error occurs. In this case, the plugin would not appear in the list of installed plugins, giving the impression that the installation was successful as 3.3.1 does.
I recommend to uninstall 3.3.1 and install version 3.3.5beta of the plugin. Before re-installing the plugin make sure the data partition has been fully expanded. If that should not be the case, the space on the SD card does not suffice for the software the plugin needs to download and install. This also leads to the abort of the plugin’s installation (versions 3.3.2+).
To check disk space connect to Volumio via SSH and run
df -h
Check fpr the size of “overlayfs”. If in doubt feel free to post the result.
An error occurred while uninstalling the plugin: Error
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p2 2.5G 1.2G 1.1G 53% /imgpart
/dev/loop0 364M 364M 0 100% /static
overlay 4.8G 31M 4.5G 1% /
devtmpfs 445M 0 445M 0% /dev
tmpfs 484M 0 484M 0% /dev/shm
tmpfs 484M 9.0M 475M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 484M 0 484M 0% /sys/fs/cgroup
tmpfs 484M 0 484M 0% /var/spool/cups
tmpfs 484M 52K 484M 1% /tmp
tmpfs 20M 36K 20M 1% /var/log
tmpfs 484M 0 484M 0% /var/spool/cups/tmp
/dev/mmcblk0p1 92M 54M 38M 59% /boot
Result of “df -h” seems to be ok - 8GB card I guess.
Since I don’t know in what state your current system might be, I suggest to start from scratch, wait at least 10 minutes after the first boot of Volumio, enable “Plugins Test Mode” and try to install version 3.3.5beta of the Touch Display plugin.
from scratch…here the end of message plugin installation
(Reading database … 34206 files and directories currently installed.)
Removing libraspberrypi0 (0.0.1) …
Reading package lists…
Building dependency tree…
Reading state information…
The following packages will be REMOVED:
raspberrypi-bootloader*
0 upgraded, 0 newly installed, 1 to remove and 33 not upgraded.
After this operation, 26.6 kB disk space will be freed.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database . … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 34202 files and directories currently installed.)
Removing raspberrypi-bootloader (0.0.1) …
raspberrypi-kernel*
0 upgraded, 0 newly installed, 1 to remove and 32 not upgraded.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database . … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 34198 files and directories currently installed.)
Removing raspberrypi kernel (0.0.1) …
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
done
Removing temporary directory touch_display-JTqfVbTP5p
An error occurred during plugin installation Error
Thank you for the report. A download error is stopping the plugin’s installation. You could try reinstalling the plugin if it is a temporary network issue, but your past experience tends to suggest that it is not.
Do you run something like piHole in your network or are you located in a region where internet traffic might be partially blocked?
ok i disable the pihole and one more time from scratch, second dns = 8.8.8.8…
xinput firmware-amd-graphics xserver-xorg-video-r128
xserver-xorg-video-mach64 xfonts-cyrillic
The following NEW packages will be installed:
keyboard-configuration libdrm-amdgpu1 libdrm-nouveau2 libdrm-radeon1
libegl-mesa0 libegl1 libegl1-mesa libepoxy0 libevdev2 libfontenc1 libgbm1
libgl1 libgl1-mesa-dri libglapi-mesa libglvnd0 libglx-mesa0 libglx0
libgudev-1.0-0 libinput-bin libinput10 libllvm9 libmtdev1 libpciaccess0
libsensors-config libsensors5 libunwind8 libutempter0 libwacom-bin
libwacom-common libwacom2 libwayland-server0 libxaw7 libxcb-dri2-0
libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-shape0 libxcb-sync1
libxcb-xfixes0 libxcomposite1 libxdamage1 libxfont2 libxft2 libxkbfile1
libxmu6 libxmuu1 libxpm4 libxshmfence1 libxt6 libxv1 libxxf86dga1 x11-utils
x11-xkb-utils xauth xbitmaps xfonts-base xfonts-encodings xfonts-utils xinit
xserver-common xserver-xorg xserver-xorg-core xserver-xorg-input-all
xserver-xorg-input-libinput xserver-xorg-input-wacom xserver-xorg-legacy
xserver-xorg-video-all xserver-xorg-video-amdgpu xserver-xorg-video-ati
xserver-xorg-video-fbdev xserver-xorg-video-nouveau
xserver-xorg-video-radeon xserver-xorg-video-vesa xterm
0 upgraded, 74 newly installed, 0 to remove and 35 not upgraded.
Need to get 21.5 MB/39.1 MB of archives.
After this operation, 581 MB of additional disk space will be used.
Err:2 Index of /debian buster/main armhf libllvm9 armhf 1:9.0.1-6+rpi1~bpo10+1
Connection failed [IP: 176.126.240.86 80]
Err:1 Index of /raspbian/raspbian buster/main armhf xfonts-encodings all 1:1.0.4-2
Connection failed [IP: 212.101.4.241 80]
Err:3 Index of /debian buster/main armhf xserver-common all 2:1.20.4-1+rpt4+deb10u4
Connection failed [IP: 46.235.227.39 80]
Err:4 Index of /debian buster/main armhf xserver-xorg-core armhf 2:1.20.4-1+rpt4+deb10u4
Connection failed [IP: 93.93.135.118 80]
Err:5 Index of /debian buster/main armhf xserver-xorg-legacy armhf 2:1.20.4-1+rpt4+deb10u4
Connection failed [IP: 93.93.130.212 80]
Installation of xinit failed
Plugin failed to install!
Cleaning up…
If the installation of the plugin fails because of such download problems there should be no need to start from scratch - just click “Install” again to make a new attempt. :slight_smile:
Can’t help much with your network configuration, but that seems to be the root cause for your problem here.
ok thanks, i’ll try for a while
now with Volumio version 3.198 from scratch, no pihole, tries to install plugin 3.3.5…
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.3.5/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.3.5/volumio/buster/armhf
Erstelle Installationspfad
Plugin wird entpackt
Prüfe, ob Plugin bereits existiert
Kopiere Plugin in sein Verzeichnis
Installiere benötigte Komponenten
Completing “UIConfig.json”
Installing fake packages for kernel, bootloader and pi lib
Selecting previously unselected package libraspberrypi0.
(Reading database … 34194 files and directories currently installed.)
Preparing to unpack …/libraspberrypi0_0.0.1_all.deb …
Unpacking libraspberrypi0 (0.0.1) …
Setting up libraspberrypi0 (0.0.1) …
Selecting previously unselected package raspberrypi-bootloader.
Preparing to unpack …/raspberrypi-bootloader_0.0.1_all.deb …
Unpacking raspberrypi-bootloader (0.0.1) …
Setting up raspberrypi-bootloader (0.0.1) …
Selecting previously unselected package raspberrypi-kernel.
Preparing to unpack …/raspberrypi-kernel_0.0.1_all.deb …
Unpacking raspberrypi-kernel (0.0.1) …
Setting up raspberrypi-kernel (0.0.1) …
Putting on hold packages for kernel, bootloader and pi lib
libraspberrypi0 set on hold.
raspberrypi-bootloader set on hold.
raspberrypi-kernel set on hold.
Installing Chromium dependencies
Get:1 Index of /raspbian buster InRelease [15.0 kB]
Get:2 Index of /debian buster InRelease [32.6 kB]
Get:3 Index of /node_14.x/ buster InRelease [4584 B]
Get:4 Index of /raspbian buster/main armhf Packages [13.0 MB]
Get:5 Index of /debian buster/main armhf Packages [393 kB]
Get:6 Index of /node_14.x/ buster/main armhf Packages [780 B]
Get:7 Index of /raspbian buster/contrib armhf Packages [58.8 kB]
Get:8 Index of /raspbian buster/non-free armhf Packages [104 kB]
Get:9 Index of /raspbian buster/rpi armhf Packages [1360 B]
Fetched 13.6 MB in 11s (1240 kB/s)
0 upgraded, 0 newly installed, 0 to remove and 40 not upgraded.
Installing graphical environment
The following additional packages will be installed:
Suggested packages:
pciutils lm-sensors mesa-utils xfonts-100dpi | xfonts-75dpi xfonts-scalable
0 upgraded, 74 newly installed, 0 to remove and 40 not upgraded.
Need to get 39.1 MB of archives.
Get:1 Index of /debian buster/main armhf libdrm-amdgpu1 armhf 2.4.100-4+rpi1~bpo10+1 [26.9 kB]
Get:3 Index of /debian buster/main armhf libdrm-nouveau2 armhf 2.4.100-4+rpi1~bpo10+1 [24.8 kB]
Get:4 Index of /debian buster/main armhf libdrm-radeon1 armhf 2.4.100-4+rpi1~bpo10+1 [29.0 kB]
Get:5 Index of /debian buster/main armhf libgbm1 armhf 19.3.2-1~bpo10+1~rpt4 [67.2 kB]
Get:6 Index of /debian buster/main armhf libglapi-mesa armhf 19.3.2-1~bpo10+1~rpt4 [78.5 kB]
Get:2 Index of /raspbian/raspbian buster/main armhf keyboard-configuration all 1.193~deb10u1 [404 kB]
Get:7 Index of /debian buster/main armhf libegl-mesa0 armhf 19.3.2-1~bpo10+1~rpt4 [120 kB]
Get:9 Index of /debian buster/main armhf libglvnd0 armhf 1.3.0-7~bpo10+1 [53.7 kB]
Get:10 Index of /debian buster/main armhf libegl1 armhf 1.3.0-7~bpo10+1 [28.5 kB]
Get:11 Index of /debian buster/main armhf libegl1-mesa armhf 19.3.2-1~bpo10+1~rpt4 [49.4 kB]
Get:12 Index of /debian buster/main armhf libllvm9 armhf 1:9.0.1-6+rpi1~bpo10+1 [13.1 MB]
Get:8 Index of /raspbian/raspbian buster/main armhf libxxf86dga1 armhf 2:1.1.4-1 [22.4 kB]
Get:13 Index of /raspbian/raspbian buster/main armhf libwayland-server0 armhf 1.16.0-1 [26.0 kB]
Get:14 Index of /raspbian/raspbian buster/main armhf libxcb-dri2-0 armhf 1.13.1-2 [100 kB]
Err:12 Index of /debian buster/main armhf libllvm9 armhf 1:9.0.1-6+rpi1~bpo10+1
Get:15 Index of /debian buster/main armhf libgl1-mesa-dri armhf 19.3.2-1~bpo10+1~rpt4 [5551 kB]
Get:16 Index of /debian buster/main armhf libglx-mesa0 armhf 19.3.2-1~bpo10+1~rpt4 [167 kB]
Get:17 Index of /raspbian/raspbian buster/main armhf libxcb-dri3-0 armhf 1.13.1-2 [100 kB]
Get:18 Index of /debian buster/main armhf libglx0 armhf 1.3.0-7~bpo10+1 [25.8 kB]
Get:19 Index of /debian buster/main armhf libgl1 armhf 1.3.0-7~bpo10+1 [104 kB]
Get:20 Index of /debian buster/main armhf xserver-common all 2:1.20.4-1+rpt4+deb10u4 [2235 kB]
Get:21 Index of /raspbian/raspbian buster/main armhf libxcb-present0 armhf 1.13.1-2 [99.1 kB]
Get:22 Index of /raspbian/raspbian buster/main armhf libxcb-sync1 armhf 1.13.1-2 [102 kB]
Err:20 Index of /debian buster/main armhf xserver-common all 2:1.20.4-1+rpt4+deb10u4
Get:23 Index of /debian buster/main armhf xserver-xorg-core armhf 2:1.20.4-1+rpt4+deb10u4 [3280 kB]
Get:24 Index of /raspbian/raspbian buster/main armhf libxcb-xfixes0 armhf 1.13.1-2 [103 kB]
Get:25 Index of /raspbian/raspbian buster/main armhf libxshmfence1 armhf 1.3-1 [8636 B]
Get:26 Index of /raspbian/raspbian buster/main armhf libepoxy0 armhf 1.5.3-0.1 [167 kB]
Get:27 Index of /raspbian/raspbian buster/main armhf libevdev2 armhf 1.6.0+dfsg-1 [24.9 kB]
Get:28 Index of /raspbian/raspbian buster/main armhf libfontenc1 armhf 1:1.1.3-1 [22.2 kB]
Get:29 Index of /raspbian/raspbian buster/main armhf libxcb-glx0 armhf 1.13.1-2 [114 kB]
Get:30 Index of /raspbian/raspbian buster/main armhf libxdamage1 armhf 1:1.1.4-3+b3 [14.3 kB]
Err:23 Index of /debian buster/main armhf xserver-xorg-core armhf 2:1.20.4-1+rpt4+deb10u4
Get:31 Index of /debian buster/main armhf xserver-xorg-legacy armhf 2:1.20.4-1+rpt4+deb10u4 [2240 kB]
Get:32 Index of /raspbian/raspbian buster/main armhf libsensors-config all 1:3.5.0-3 [31.6 kB]
Get:33 Index of /raspbian/raspbian buster/main armhf libsensors5 armhf 1:3.5.0-3 [49.5 kB]
Get:34 Index of /raspbian/raspbian buster/main armhf libgudev-1.0-0 armhf 232-2+rpi1 [11.8 kB]
Err:31 Index of /debian buster/main armhf xserver-xorg-legacy armhf 2:1.20.4-1+rpt4+deb10u4
Connection failed [IP: 46.235.231.145 80]
Get:35 Index of /raspbian/raspbian buster/main armhf libwacom-common all 0.32-1 [39.1 kB]
Get:36 Index of /raspbian/raspbian buster/main armhf libwacom2 armhf 0.32-1 [16.1 kB]
Get:37 Index of /raspbian/raspbian buster/main armhf libinput-bin armhf 1.12.6-2+deb10u1 [16.5 kB]
Get:38 Index of /raspbian/raspbian buster/main armhf libmtdev1 armhf 1.1.5-1+b2 [21.2 kB]
Get:39 Index of /raspbian/raspbian buster/main armhf libinput10 armhf 1.12.6-2+deb10u1 [90.7 kB]
Get:40 Index of /raspbian/raspbian buster/main armhf libpciaccess0 armhf 0.14-1 [51.0 kB]
Get:41 Index of /raspbian/raspbian buster/main armhf libunwind8 armhf 1.2.1-10~deb10u1 [47.1 kB]
Get:42 Index of /raspbian/raspbian buster/main armhf libutempter0 armhf 1.1.6-3 [7736 B]
Get:43 Index of /raspbian/raspbian buster/main armhf libwacom-bin armhf 0.32-1 [6528 B]
Get:44 Index of /raspbian/raspbian buster/main armhf libxt6 armhf 1:1.1.5-1+b3 [156 kB]
Get:45 Index of /raspbian/raspbian buster/main armhf libxmu6 armhf 2:1.1.2-2+b3 [52.1 kB]
Get:46 Index of /raspbian/raspbian buster/main armhf libxpm4 armhf 1:3.5.12-1 [43.6 kB]
Get:47 Index of /raspbian/raspbian buster/main armhf libxaw7 armhf 2:1.0.13-1+b2 [163 kB]
Get:48 Index of /raspbian/raspbian buster/main armhf libxcb-shape0 armhf 1.13.1-2 [99.5 kB]
Get:49 Index of /raspbian/raspbian buster/main armhf libxcomposite1 armhf 1:0.4.4-2 [16.1 kB]
Get:50 Index of /raspbian/raspbian buster/main armhf libxfont2 armhf 1:2.0.3-1 [120 kB]
Get:51 Index of /raspbian/raspbian buster/main armhf libxft2 armhf 2.3.2-2 [49.3 kB]
Get:52 Index of /raspbian/raspbian buster/main armhf libxkbfile1 armhf 1:1.0.9-2 [65.4 kB]
Get:53 Index of /raspbian/raspbian buster/main armhf libxmuu1 armhf 2:1.1.2-2+b3 [23.4 kB]
Get:54 Index of /raspbian/raspbian buster/main armhf libxv1 armhf 2:1.0.11-1 [23.2 kB]
Get:55 Index of /raspbian/raspbian buster/main armhf x11-utils armhf 7.7+4 [176 kB]
Get:56 Index of /raspbian/raspbian buster/main armhf x11-xkb-utils armhf 7.7+4 [138 kB]
Get:57 Index of /raspbian/raspbian buster/main armhf xauth armhf 1:1.0.10-1 [36.4 kB]
Get:58 Index of /raspbian/raspbian buster/main armhf xbitmaps all 1.1.1-2 [32.1 kB]
Get:59 Index of /raspbian/raspbian buster/main armhf xfonts-encodings all 1:1.0.4-2 [574 kB]
Err:59 Index of /raspbian/raspbian buster/main armhf xfonts-encodings all 1:1.0.4-2
Get:60 Index of /raspbian/raspbian buster/main armhf xfonts-utils armhf 1:7.7+6 [82.5 kB]
Get:61 Index of /raspbian/raspbian buster/main armhf xfonts-base all 1:1.0.5 [5897 kB]
Get:62 Index of /raspbian/raspbian buster/main armhf xinit armhf 1.4.0-1 [49.4 kB]
Get:63 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-amdgpu armhf 18.1.99+git20190207-1 [122 kB]
Get:64 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-radeon armhf 1:19.0.1-1 [487 kB]
Get:65 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-ati armhf 1:19.0.1-1 [363 kB]
Get:66 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-fbdev armhf 1:0.5.0-1+b2 [24.4 kB]
Get:67 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-nouveau armhf 1:1.0.16-1 [318 kB]
Get:68 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-vesa armhf 1:2.4.0-1+b1 [30.6 kB]
Get:69 Index of /raspbian/raspbian buster/main armhf xserver-xorg-video-all armhf 1:7.7+19+b8 [38.3 kB]
Get:70 Index of /raspbian/raspbian buster/main armhf xserver-xorg-input-libinput armhf 0.28.2-2 [58.1 kB]
Get:71 Index of /raspbian/raspbian buster/main armhf xserver-xorg-input-all armhf 1:7.7+19+b8 [38.3 kB]
Get:72 Index of /raspbian/raspbian buster/main armhf xserver-xorg-input-wacom armhf 0.34.99.1-1+b6 [83.0 kB]
Get:73 Index of /raspbian/raspbian buster/main armhf xserver-xorg armhf 1:7.7+19+b8 [94.0 kB]
Get:74 Index of /raspbian/raspbian buster/main armhf xterm armhf 344-1+deb10u2 [718 kB]
Fetched 17.6 MB in 13s (1395 kB/s)
Cleaning up…
Removing dependencies
Package ‘fonts-arphic-ukai’ is not installed, so not removed
Package ‘fonts-arphic-gbsn00lp’ is not installed, so not removed
Package ‘fonts-unfonts-core’ is not installed, so not removed
Canceled hold on libraspberrypi0.
Canceled hold on raspberrypi-bootloader.
Canceled hold on raspberrypi-kernel.
Package ‘chromium-browser’ is not installed, so not removed
Package ‘openbox’ is not installed, so not removed
Package ‘xinit’ is not installed, so not removed
libraspberrypi0*
0 upgraded, 0 newly installed, 1 to remove and 39 not upgraded.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 34206 files and directories currently installed.)
0 upgraded, 0 newly installed, 1 to remove and 38 not upgraded.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 34202 files and directories currently installed.)
raspberrypi-kernel*
0 upgraded, 0 newly installed, 1 to remove and 37 not upgraded.
(Reading database … (Reading database … 5% (Reading database … 10% (Reading database … 15% (Reading database … 20% (Reading database … 25% (Reading database … 30% (Reading database … 35% (Reading database … 40% (Reading database … 45% (Reading database … 50% (Reading database … 55% (Reading database … 60% (Reading database … 65% (Reading database … 70% (Reading database … 75% (Reading database … 80% (Reading database … 85% (Reading database … 90% (Reading database … 95% (Reading database … 100% (Reading database … 34198 files and directories currently installed.)
Removing raspberrypi-kernel (0.0.1) …
Done
Removing temporary directory touch_display-LxOPmiaP0M
Es ist ein Fehler während der Plugin-Installation aufgetreten Error
Are you able to successfully ping the IP addresses from your Pi where the log shows “Connection failed”?
do you mean this?
Ping 192.168.1.239 PING 192.168.1.239 (192.168.1.239) 56(84) bytes of data. 64 bytes of 192.168.1.239: icmp_seq=1 ttl=64 time=0.363 ms 64 bytes of 192.168.1.239: icmp_seq=2 ttl=64 time=0.356 ms 64 bytes of 192.168.1.239: icmp_seq=3 ttl=64 time=0.385 ms 64 bytes of 192.168.1.239: icmp_seq=4 ttl=64 time=0.455 ms 64 bytes of 192.168.1.239: icmp_seq=5 ttl=64 time=0.410 ms 64 bytes of 192.168.1.239: icmp_seq=6 ttl=64 time=0.359 ms 64 bytes of 192.168.1.239: icmp_seq=7 ttl=64 time=0.383 ms
volumio@volumiodach:~$ ping 46.235.230.122 80
PING 80 (0.0.0.80) 56(124) bytes of data.
^C
— 80 ping statistics —
39 packets transmitted, 0 received, 100% packet loss, time 579ms
