I’ve got the touchscreen set up (2.348+official 7" touch screen) and am using the plug in. Works great.
One problem I’ve come across. When in the music library view, if you click the 3-dot menu to the right of one of the first listed songs or albums, the pop up menu extends off screen above. Later songs is no problem as you can adjust the scrolling location first. An earlier version of Volumio had this same problem in the general GUI.
Any solution. Not a huge problem as I can always work around with my phone.
Thanks for ideas.
Mike
