This post is a split from the “Touch/Hyperpixel” post, as the two issues appear unrelated, so this issue has been moved to a separate post.
Below are the results of the tests you asked for.
Result of “X -version” is:
X.Org X Server 1.18.4
Release Date: 2016-07-19
Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Current Operating System: Linux volumio_sunroom 4.19.86-v7+ #1283 SMP Fri Nov 29 18:32:25 GMT 2019 armv7l
Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0
Build Date: 11 November 2016 11:59:59AM
xorg-server 2:1.18.4-2+rpi1 (debian.org/support)
Current version of pixman: 0.32.6
Before reporting problems, check wiki.x.org
Result of “chromium-browser -version” is:
/usr/bin/chromium-browser: line 138: lsb_release: command not found
/usr/bin/chromium-browser: line 139: lsb_release: command not found
Inconsistency detected by ld.so: dl-lookup.c: 871: _dl_setup_hash: Assertion `(bitmask_nwords & (bitmask_nwords - 1)) == 0’ failed!
[NOTE: get same lack of lsb_release report on the working system, but do not get the INCONSISTENCY error, so that third error line appears to
be important]
Next is result of “sudo journalctl -f” starting with plugin running, then stopping plugin, then starting it again.
I have added comment lines at about the points where I think I stopped/started the plugin, but I may be wrong sorry if
that is the case.
THIS BIT IS WHILE PLUGIN IS STILL RUNNING::::::
– Logs begin at Thu 2020-03-12 14:06:18 UTC. –
Mar 13 07:27:22 volumio_sunroom systemd[28013]: Starting Basic System.
Mar 13 07:27:22 volumio_sunroom systemd[28013]: Reached target Basic System.
Mar 13 07:27:22 volumio_sunroom systemd[28013]: Starting Default.
Mar 13 07:27:22 volumio_sunroom systemd[28013]: Reached target Default.
Mar 13 07:27:22 volumio_sunroom systemd[28013]: Startup finished in 28ms.
Mar 13 07:27:22 volumio_sunroom systemd[1]: Started User Manager for UID 1000.
Mar 13 07:27:22 volumio_sunroom sshd[26230]: lastlog_openseek: Couldn’t stat /var/log/lastlog: No such file or directory
Mar 13 07:33:08 volumio_sunroom sudo[9293]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Mar 13 07:33:08 volumio_sunroom sudo[9293]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
THINK THIS IS WHERE I STOPPED PLUGIN (or may be nearer to 07:34) :::::
Mar 13 07:33:52 volumio_sunroom sudo[19317]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
Mar 13 07:33:52 volumio_sunroom sudo[19317]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:33:52 volumio_sunroom sudo[19323]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 13 07:33:52 volumio_sunroom sudo[19317]: pam_unix(sudo:session): session closed for user root
Mar 13 07:33:52 volumio_sunroom sudo[19323]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:33:52 volumio_sunroom sudo[19323]: pam_unix(sudo:session): session closed for user root
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::volumioGetVisibleSources
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: my_music , getDisabledSources
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::volumioGetState
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreStateMachine::getState
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CorePlayQueue::getTrack 0
Mar 13 07:33:53 volumio_sunroom sudo[19569]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: appearance , getUiSettings
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
Mar 13 07:33:53 volumio_sunroom sudo[19569]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
Mar 13 07:33:53 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
Mar 13 07:33:54 volumio_sunroom sudo[19569]: pam_unix(sudo:session): session closed for user root
Mar 13 07:33:54 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: multiroom , getMultiroom
Mar 13 07:33:54 volumio_sunroom sudo[19594]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 13 07:33:54 volumio_sunroom volumio[955]: info: Listing playlists
Mar 13 07:33:54 volumio_sunroom sudo[19594]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:33:54 volumio_sunroom sudo[19594]: pam_unix(sudo:session): session closed for user root
Mar 13 07:33:54 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Mar 13 07:34:07 volumio_sunroom volumio[955]: info: Un-/commenting gpu_mem settings in /boot/config.txt.
Mar 13 07:34:07 volumio_sunroom volumio[955]: info: Using /boot/config.txt instead of /boot/userconfig.txt.
Mar 13 07:34:07 volumio_sunroom volumio[955]: info: Disabling plugin touch_display
Mar 13 07:34:07 volumio_sunroom volumio[955]: info: Done.
Mar 13 07:34:07 volumio_sunroom sudo[22744]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop volumio-kiosk.service
Mar 13 07:34:07 volumio_sunroom sudo[22744]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:07 volumio_sunroom systemd[1]: Stopping Volumio Kiosk…
Mar 13 07:34:07 volumio_sunroom startx[11513]: xinit: connection to X server lost
Mar 13 07:34:07 volumio_sunroom pulseaudio[11657]: PulseAudio information vanished from X11!
Mar 13 07:34:07 volumio_sunroom bluetoothd[784]: Endpoint unregistered: sender=:1.23 path=/MediaEndpoint/A2DPSource
Mar 13 07:34:07 volumio_sunroom bluetoothd[784]: Endpoint unregistered: sender=:1.23 path=/MediaEndpoint/A2DPSink
Mar 13 07:34:08 volumio_sunroom sudo[22737]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sed -i -e /Option “TransformationMatrix”/d /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
Mar 13 07:34:08 volumio_sunroom sudo[22737]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:08 volumio_sunroom sudo[22737]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:08 volumio_sunroom startx[11513]: waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Mar 13 07:34:08 volumio_sunroom volumio[955]: info: Touchscreen transformation matrix removed.
Mar 13 07:34:08 volumio_sunroom sudo[22770]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sed -i -e /Identifier “Touch rotation”/a\ Option “TransformationMatrix” “undefined” /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
Mar 13 07:34:08 volumio_sunroom sudo[22770]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:08 volumio_sunroom sudo[22770]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:08 volumio_sunroom volumio[955]: info: Touchscreen transformation matrix written.
Mar 13 07:34:08 volumio_sunroom startx[11513]: xinit: unexpected signal 15
Mar 13 07:34:09 volumio_sunroom systemd[1]: volumio-kiosk.service: main process exited, code=exited, status=1/FAILURE
Mar 13 07:34:09 volumio_sunroom systemd[1]: Stopped Volumio Kiosk.
Mar 13 07:34:09 volumio_sunroom systemd[1]: Unit volumio-kiosk.service entered failed state.
Mar 13 07:34:09 volumio_sunroom sudo[22744]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:09 volumio_sunroom volumio[955]: info: systemctl stop volumio-kiosk.service succeeded.
Mar 13 07:34:09 volumio_sunroom volumio[955]: info: Volumio Kiosk stopped
THEN I THINK THIS IS WHERE I STARTED PLUGIN AGAIN:::::
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Enabling plugin touch_display
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Loading plugin “touch_display”…
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Applying required configuration parameters for plugin touch_display
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: PLUGIN START: touch_display
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Loading i18n strings for locale en
Mar 13 07:34:33 volumio_sunroom sudo[22850]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl daemon-reload
Mar 13 07:34:33 volumio_sunroom sudo[22850]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:33 volumio_sunroom systemd[1]: Reloading.
Mar 13 07:34:33 volumio_sunroom systemd[1]: [/lib/systemd/system/mpd.service:18] Unknown lvalue ‘ProtectKernelTunables’ in section ‘Service’
Mar 13 07:34:33 volumio_sunroom systemd[1]: [/lib/systemd/system/mpd.service:19] Unknown lvalue ‘ProtectControlGroups’ in section ‘Service’
Mar 13 07:34:33 volumio_sunroom systemd[1]: [/lib/systemd/system/mpd.service:20] Unknown lvalue ‘ProtectKernelModules’ in section ‘Service’
Mar 13 07:34:33 volumio_sunroom systemd[1]: [/lib/systemd/system/mpd.service:23] Unknown lvalue ‘RestrictNamespaces’ in section ‘Service’
Mar 13 07:34:33 volumio_sunroom sudo[22850]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: systemctl daemon-reload succeeded.
Mar 13 07:34:33 volumio_sunroom sudo[22870]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volumio-kiosk.service
Mar 13 07:34:33 volumio_sunroom sudo[22870]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:33 volumio_sunroom systemd[1]: Starting Volumio Kiosk…
Mar 13 07:34:33 volumio_sunroom systemd[1]: Started Volumio Kiosk.
Mar 13 07:34:33 volumio_sunroom startx[22875]: X.Org X Server 1.18.4
Mar 13 07:34:33 volumio_sunroom startx[22875]: Release Date: 2016-07-19
Mar 13 07:34:33 volumio_sunroom startx[22875]: X Protocol Version 11, Revision 0
Mar 13 07:34:33 volumio_sunroom startx[22875]: Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
Mar 13 07:34:33 volumio_sunroom startx[22875]: Current Operating System: Linux volumio_sunroom 4.19.86-v7+ #1283 SMP Fri Nov 29 18:32:25 GMT 2019 armv7l
Mar 13 07:34:33 volumio_sunroom startx[22875]: Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=800 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0
Mar 13 07:34:33 volumio_sunroom startx[22875]: Build Date: 11 November 2016 11:59:59AM
Mar 13 07:34:33 volumio_sunroom startx[22875]: xorg-server 2:1.18.4-2+rpi1 (debian.org/support)
Mar 13 07:34:33 volumio_sunroom startx[22875]: Current version of pixman: 0.32.6
Mar 13 07:34:33 volumio_sunroom startx[22875]: Before reporting problems, check wiki.x.org
Mar 13 07:34:33 volumio_sunroom startx[22875]: to make sure that you have the latest version.
Mar 13 07:34:33 volumio_sunroom startx[22875]: Markers: (–) probed, (**) from config file, (==) default setting,
Mar 13 07:34:33 volumio_sunroom startx[22875]: (++) from command line, (!!) notice, (II) informational,
Mar 13 07:34:33 volumio_sunroom startx[22875]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 13 07:34:33 volumio_sunroom startx[22875]: (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Mar 13 07:34:33 2020
Mar 13 07:34:33 volumio_sunroom startx[22875]: (==) Using config directory: “/etc/X11/xorg.conf.d”
Mar 13 07:34:33 volumio_sunroom startx[22875]: (==) Using system config directory “/usr/share/X11/xorg.conf.d”
Mar 13 07:34:33 volumio_sunroom startx[22875]: modprobe: FATAL: Module g2d_23 not found.
Mar 13 07:34:33 volumio_sunroom sudo[22870]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: systemctl start volumio-kiosk.service succeeded.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Volumio Kiosk started
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: CoreCommandRouter::volumioGetState
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: CoreStateMachine::getState
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: CorePlayQueue::getTrack 0
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Done.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Raspberry Pi Foundation touch screen detected.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Using /boot/config.txt instead of /boot/userconfig.txt.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Un-/commenting gpu_mem settings in /boot/config.txt.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Backlight module of a Raspberry Pi Foundation touch screen detected.
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Using Xorg socket /tmp/.X11-unix/X0
Mar 13 07:34:33 volumio_sunroom sudo[22916]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 13 07:34:33 volumio_sunroom sudo[22916]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:33 volumio_sunroom sudo[22916]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:33 volumio_sunroom sudo[22914]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/sed -i -e /Option “TransformationMatrix”/d /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
Mar 13 07:34:33 volumio_sunroom sudo[22914]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:34:33 volumio_sunroom sudo[22914]: pam_unix(sudo:session): session closed for user root
Mar 13 07:34:33 volumio_sunroom volumio[955]: info: Touchscreen transformation matrix removed.
Mar 13 07:34:34 volumio_sunroom volumio[955]: info: Setting screensaver timeout to 120 seconds.
Mar 13 07:34:34 volumio_sunroom pulseaudio[23055]: Stale PID file, overwriting.
Mar 13 07:34:34 volumio_sunroom pulseaudio[23055]: Unable to contact D-Bus: org.freedesktop.DBus.Error.Spawn.ExecFailed: /usr/bin/dbus-launch terminated abnormally without any error message
Mar 13 07:34:34 volumio_sunroom pulseaudio[23055]: org.bluez.Manager.GetProperties() failed: org.freedesktop.DBus.Error.UnknownMethod: Method “GetProperties” with signature “” on interface “org.bluez.Manager” doesn’t exist
Mar 13 07:34:34 volumio_sunroom bluetoothd[784]: Endpoint registered: sender=:1.31 path=/MediaEndpoint/A2DPSource
Mar 13 07:34:34 volumio_sunroom bluetoothd[784]: Endpoint registered: sender=:1.31 path=/MediaEndpoint/A2DPSink
