Touch Display plugin on RPi4 with Composite out keeps restarting (configuration update message)
Flashed latest version of Volumio on an SD card and inserted in Raspberry Pi 4. That works fine and can make all config and use the webportal.
Activated the Touch Screen plugin, works as well. No errors, nothing special.
Now switched ON the Composite Out with the following in the userconfig.txt (PAL televion, 4:3 aspect, Black&White only):
enable_tvout=1
display_auto_detect=1
dtoverlay=vc4-kms-v3d,cma-384,composite=1
sdtv_mode=2
sdtv_aspect=1
sdtv_disable_colourburst=1
And output on CRT television works (I can see the boot screen, I can also see the touch screen starting).
But now an infinite loop of “Configuration Update - Player successfully restarted” kicks of. Making Volumio practically unusable as I cannot get into the menu to uninstall the plugin.
Test with exact same steps on an RPi 3; this works fine. No loops, just works.
Even inserted that same SD card in the RPi 4, and loop again.
Sending the Error Log does not work via the device dev page, the disconnects are too fast to get the report processed. If there is another way to get the same log files, please help me on that.
Dumping live log works:
Starting Live Log…
info: CoreCommandRouter::executeOnPlugin: alsa_controller , getConfigParam
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
[2025-05-25 16:35:15] [connect] Successful connection
info: touch_display: No Raspberry Pi Foundation touch screen detected.
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod a+rw /etc/X11/xorg.conf.d/99-vc4.conf
/lib/systemd/system/winbind.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/winbindd.pid → /run/samba/winbindd.pid; please update the unit file accordingly.
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod a+rw /etc/X11/xorg.conf.d/95-touch_display-plugin.conf
[2025-05-25 16:35:15] [connect] WebSocket Connection 127.0.0.1:3000 v-2 “WebSocket++/0.8.2” /socket.io/?EIO=4&transport=websocket&t=1748183715 101
info: Starting Shairport Sync
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart shairport-sync
info: touch_display: File permissions for /etc/X11/xorg.conf.d/99-vc4.conf set.
info: touch_display: File permissions for /etc/X11/xorg.conf.d/95-touch_display-plugin.conf set.
Reloading.
info: touch_display: systemctl disable getty@tty1.service succeeded.
May 25 16:35 : decoder: Decoder plugin ‘wildmidi’ is unavailable: configuration file does not exist: /etc/timidity/timidity.cfg
Started Music Player Daemon.
info: touch_display: systemctl daemon-reload succeeded.
Stopping Shairport Sync - AirPlay Audio Receiver…
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volumio-kiosk.service
shairport-sync.service: Succeeded.
Stopped Shairport Sync - AirPlay Audio Receiver.
error: MPD error: The expression evaluated to a falsy value:
assert.ok(self.idling)
error: updateQueue error: null
info: MPD running with PID9356
,establishing connection
Started Shairport Sync - AirPlay Audio Receiver.
info: Shairport-Sync Started
Error adding Membership: Error: addMembership EINVAL
info: touch_display: systemctl start volumio-kiosk.service succeeded.
info: touch_display: Volumio Kiosk started.
info: Completed starting Core Plugins
info: -------------------------------------------
info: ----- MyVolumio plugins startup ----
info: [MyVolumio PluginManager] Fetching plans data…
info: touch_display: X display number found: 0
Other topics in the forum said the wifi is not stable, so connecting via ethernet now.
Tried using the DNS 8.8.8.8 on an earlier run, no difference.
SD card is fresh new. And it works fine on RPi 3 with same card.
Flashing is done with the Raspberry Imager, not with Balena.
Please help, any advice is appreciated!
Fixed it!
Replaced this line of my userconfig.txt:
with:
dtoverlay=vc4-fkms-v3d,cma-384,composite=1
Only change is the character F
Found it based on this note somewhere on reddit:
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
