Adding display_lcd_rotate=2
to userconfig.txt worked.
that file is now
lcd_rotate=2
display_hdmi_rotate=2
I suppose display_hdmi_rotate=2
is not required
Sorry to take a while to come back to you, was out this afternoon. lsmod below…
many thanks for your help
volumio@living:~$ lsmod
Module Size Used by
bnep 20480 2
hci_uart 40960 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 389120 24 hci_uart,bnep,btbcm
xt_REDIRECT 16384 1
xt_tcpudp 16384 1
iptable_nat 16384 1
nf_nat_ipv4 16384 1 iptable_nat
nf_nat 36864 2 nf_nat_ipv4,xt_REDIRECT
nf_conntrack 135168 3 nf_nat_ipv4,xt_REDIRECT,nf_nat
ecdh_generic 28672 1 bluetooth
nf_defrag_ipv6 20480 1 nf_conntrack
nf_defrag_ipv4 16384 1 nf_conntrack
ip_tables 24576 1 iptable_nat
x_tables 32768 3 ip_tables,xt_tcpudp,xt_REDIRECT
nfsd 319488 2
brcmfmac 315392 0
joydev 20480 0
brcmutil 16384 1 brcmfmac
snd_usb_audio 192512 2
cfg80211 651264 1 brcmfmac
snd_hwdep 16384 1 snd_usb_audio
snd_usbmidi_lib 32768 1 snd_usb_audio
snd_seq_midi 16384 0
snd_seq_midi_event 16384 1 snd_seq_midi
snd_rawmidi 32768 2 snd_seq_midi,snd_usbmidi_lib
evdev 24576 4
snd_bcm2835 24576 1
snd_seq 69632 2 snd_seq_midi_event,snd_seq_midi
snd_pcm 102400 3 snd_usb_audio,snd_bcm2835
bcm2835_v4l2 45056 0
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
bcm2835_codec 36864 0
v4l2_mem2mem 24576 1 bcm2835_codec
snd_timer 32768 2 snd_seq,snd_pcm
v4l2_common 16384 1 bcm2835_v4l2
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
videobuf2_vmalloc 16384 1 bcm2835_v4l2
videobuf2_dma_contig 20480 1 bcm2835_codec
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
rfkill 28672 4 bluetooth,cfg80211
videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
snd 73728 14 snd_hwdep,snd_seq,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_pcm
videodev 200704 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
raspberrypi_hwmon 16384 0
hwmon 16384 1 raspberrypi_hwmon
media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem
i2c_bcm2835 16384 0
vc_sm_cma 36864 1 bcm2835_mmal_vchiq
rpivid_mem 16384 0
uio_pdrv_genirq 16384 0
uio 20480 1 uio_pdrv_genirq
rpi_ft5406 16384 0
rpi_backlight 16384 0
i2c_dev 20480 0
ipv6 454656 106
fuse 110592 1
squashfs 45056 1
overlay 106496 1
