Greetings,
There is a bug with the installation of the Touch Display plug-in. It hangs during installation.
The cause is the keyboard-configuration package. It is expecting input from the user. Since it is being installed in the background the user is not aware it needs input and is unable to supply the input.
Work around is to log in or ssh in and enter:
sudo dpkg --configure -a
Proper input can then be entered. Now uninstall the plug-in from the plug-in menu of the web interface, reboot, reinstall Touch Display plugin and reboot once more.
It should function as expected at this point.
Randy
