I’m the owner of a volumio primo with lifetime license
I didn’t use my device for 3 monthes due to temporary change of music hardware configuration (integrated amplifier with airplay capabilities) and because, even If i found that using LMS could fix the small bugs i faced using spotify plugin, i was not totally satisfied by my user experience.
A couple of days ago, I tried to come back to volumio, i did the pending update and tried to figure all this out.
The new situation was : even more bugs with last spotify version (due to librespot, strange because forked DAAP didn’t face this issue) and now even LMS plugin is totally broken (native and docker version).
I’ve posted corresponding log in two topic elsewhere, i won’t post them again here. during the painfull process, I tried via /dev to install beta, this worked but din’t fix spotify and LMS issues.
Now I try to revert back to standard volumio version following this procedure from the documentation
Factory Reset Via USB Thumb Drive
• Get a USB Thumb Drive
• Format it as “FAT32”
• Download the factory reset file from http://repo.volumio.org/Primo/factory_reset
• Copy the file on the thumb drive and make sure it’s called exactly “factory_reset”
• Remove power from Primo
• Plug the thumb drive to one of the USB ports
• Apply power to Primo
• IMPORTANT: During this phase the unit might restart multiple times and this factory reset
will take about 10 minutes
But it doesn’t work I’M stuck to 3.369 version.
Of course standard factory reset via web interface doesn’t work more
To help here is my log trying to cancel test mode
info: CALLMETHOD: system_controller system setTestSystem false
info: CoreCommandRouter::executeOnPlugin: system , setTestSystem
error: Cannot delete test file: Error: Command failed: rm /data/test
rm: cannot remove '/data/test': No such file or directory
In last resort I’ve tried to open my case to connect micro usb port to my linux and windows PC, I can’t even see it in the explorer… I Was ready to manually flash emmc using tinkerboad volumio image but standard UMS procedure i found somewhere in this forum didn’t work for me and I couldn’t succeed…
Does all this things sound to you ? Could it be hardware related ? Could i expect any help ?
Sorry for this long message
