Hi
I’ve been using Volumio since Raspyfi with my Topping TP 30 via USB with no problem. I loaded up the new Pi image and now have no audio via USB.
All music is on a NAS share which is found and loaded correctly.
Any idea what settings I need to use (or it’s back to Rune audio for me)
Goto MENU>Playback and change the Audio Output Dropdown menu.
see what happens
Still no luck, tested with either USB or ALSA selected.
Get a pop from the speakers when Volumio starts but no sound after that
cmh714
4
sounds like something in mpd.conf isnt correct but you didnt include any information for anyone to help you…
