Hello everyone,
I have a Tinkerboard S that I find particularly powerful. I’d like to replace my raspberry Pi4 with the tinkerboard.
However, I would like to be able to connect my Hifiberry Digi2 PRO card so that I can connect it to my amplifier via the optical output using a toslink cable.
I’ve read several posts on this subject but some were old and others less so… I also understood that the GPIO terminals on the tinkerboard were the same as those on the raspberry.
The DAC I2S configuration is not available in the Tinkerboard version of Volumio3.
Is it possible to plug my Hifiberry Digi2 PRO card directly into my tinkerboard? Are there any settings to be made? Do any of you have the same type of configuration?
Thanks in advance for any feedback or links to existing solutions.
