Recently I picked up a tinker board thinking to replace my Raspberry Pi 3B+/Volumio setup but I’m having some issues.
In my original setup, I had the Raspberry Pi 3B+ connected to a stand alone DAC(PS AUDIO) via DATA, BCK and LRCK from GPIO through an I2s transmitter board and on Volumio DAC selection, the “Generic I2s DAC” was chosen. This setting was working flawlessly.
Now with the Tinker Board/Volumio setup, the GPIO pin assignment for DATA, BCK and LRCK are identical with the Raspberry Pi 3B+ so there should be no problem but among the Volumio I2s DAC selection pull down menu, there is no more “Generic I2s Dac” to choose from.
All I want from this Tinker Board/Volumio setup is DATA, BCK and LRCK signals so how should I set up Volumio? Please help.
Alright, I was informed by a fellow tinker board/volumio user that the current version volumio(as of Jul 6 2019) somehow does’nt work but the previous versions including 2.555 does work(confirmed). Just need to configure it as hifiberry dac within volumio 2.555
Tinkerboard sound is possible with Armbian, however I have not worked to get it set up “out of the box” because of a major bug in the sound itself, namely that it outputs pure high pitched garbage from certain applications and certain source materials. I don’t want anyone going deaf/destroying equipment, and I don’t want to get backed into a corner on something I don’t immediately know how to fix.
Hi sugano,
Have you been able to fix that issue? I have the same setup - RPI 3B+ with a PS Audio Stellar DAC, which works perfectly. I had to use the R-PI DAC instead of Generic I2S DAC to play 16 bit files properly, and it plays everything, DSD included.
Then I tried the Tinker Board S, but I wasn’t able to connect to the DAC via I2S at all. I would like to move away from the PI, as the Web Interface seems to work much better on the Tinker Board, so any tips are appreciated!
Thanks!
i asked around but couldn’t get it to work with tinkerboard.
was using tinkerboard usb output for a while but i eventually went for raspi with digione signature since and this has been the best sounding solution to me! seriously, the digione signature improvement is pretty significant.
Thanks!
I am sticking with the I2S route on the Pi. I am running the I2S signal through IAN Canada’s Ultimate FiFoPi, then off to the PS Audio DAC. The upgrade oscillators for the FiFoPi should come in today.
I am not sure if I will do more on the power supply side, but I think this setup already sounds quite good.
Cheers
