Timed Play(Solved)
example ;
12.45 aaa.mp3 auto play 1x repeat and stop,
13.45 bbb.mp3 auto play 1x repeat and stop
How do it ?
Alarm function :wink:
How ? :slight_smile:
1- Create a playlist with the file you want to play (if you want to play 2 files at different times, create 2 playlist with those 2 files)
2- From settings menu go to alarm
3- add new alarm
4- select the playlist and the time when you want it to play
5- save
done
Thx you so much :mrgreen:
