i am using 2.502 with VIRTUOSO.
I am not able to add my device wit Tidal.
Can you tell me how?
Hi please login into myvolumio from the ui from the pi IP address. You should see your device then in your profile page. After that go to my music settings and you ll find tidal
After, i just see a message “To use streaming service, you must have Myvolumio.”
I still cannot see any device after logon . You can see the above screen.
