I’m posting this again, but simpler:
Is it possible to use Bubble uPnP (android app) to stream Tidal to Volumio? When I try that, I get no sound. Using Bubble uPnP to stream from my local uPnP server (synology) works fine.
Check the settings for Tidal in bubble upnp and make sure you choose the same audio quality as you have in your subscription than it works perfectly.
Gesendet von meinem BTV-DL09 mit Tapatalk
