Tidal (as source) only seems to stream at CD quality (16/44.1).
Local ripped files of all higher resolution from network file shared source stream fine.
Is there a setting somewhere I’ve missed?
I will give that a try.
That worked.
Many thanks.
What is “Highest Possible” supposed to mean?
it was supposed to give the highest possible bitrate, basically what “High Res” does.
this is a bug on the Tidal SDK, it was introduced some time ago and never fixed by Tidal.
fortunately the workaround works fine
