tidal service is not activated
hi.
i need help on myvolumio tidal playback. The problem that i encountered is tidal service is not avaliable automatically when i starting myvolumio from my rasspberry pi. I cannot locate tidal icon at main screen as well as tidal account setting from the setup --> ‘source’ page.
To have tidal function appear at the main screen, i need to manually go to myvolumio session and reset the connection (disable myvolumio function and then enable it back again). Once, i performed this process sequence, the tidal service is activated.
It seem like the activation process is not working automatically, i need to manually to trigger it whenever i restart the unit. Please advise.
thanks and regards
KL Tham
