Tidal seems to be adding tracks to my queue
I am getting tracks added to the queue that I didn’t add myself.
My typical use is to find one or more albums on Tidal I want to hear and click Play (or Play Next or Add To Queue if the currently playing album isn’t finished) for the album so all tracks from that album get added to the queue.
At some point during playback Tidal seems to decide to add its own ideas of what else I might want to listen to.
Is this a bug or a feature and if it’s a feature how do I disable it?
Using v3.703
I guess your running Volumio with payed license and have Infinity play turned on?
Since a few weeks I experience this adding tracks but from the usb harddisk when playing from the usb harddisk on Primo v1
And sometimes crashes at the last song of the album
You need to elaborate a bit more.
I expect you have enabled “Infinity playback” . Depending on the settings in sources it takes tracks form the sources you’ve enabled.
A bit strange but that was happening. The infinity playing was turned on. I turned it off and it is working fine now. Thanks!
