I recently added a touch screen to my system. I couldn’t get it to work at first, long story short, I ended up reinstalling Volumio. Prior to that, I was able to stream Tidal more or less directly from Volumio, that is to say I didn’t need “Tidal Connect” to select most of my Tidal favorites and my playlist etc.
Now that I have reinstalled Volumio, I can’t get anything to play from it without using Tidal connect. I can skip to the next song, but that’s it, and even then a lot of times it just stops playing, and a lot of times I have to restart Volumio or Tidal, and a lot of times, I try to stream from Tidal connect to Volumio, and I get an error, and then “Volumio” no longer shows up as an option in “Tidal Connect” it just disappears.
Any way…any help would be appreciated. I am using an Ian Canada streamer with a RPi 5, and if you need more info I’ll provide it of course…thanks in advance.
