Tidal not showing all my Playlists
Hi friends,
for a few weeks now, I have had restrictions on the use of my Tidal account in volumio (not Tidal Connect).
Most of my playlists are missing. I was wondering why some of them are still there. I found out that only the playlists that I have created in Tidal are displayed. I have to say that most of my playlists come from Spotify, which I convert to Tidal using the Soundiz service. This has worked well for years.
Somewhere on the way to volumio, these playlists are now filtered and no longer displayed. All my playlists are still available on Tidal itself. Could you please check if there have been any changes to the Tidal API?
By the way, the sorting of my Tidal title list, album list ans playlists can no longer be changed either
Thanks, jens
we are aware of that and we are investigating on it with Tidal
Thanks for your patience
Davide
VOLUMIO TECH SUPPORT
Thanks for the report @judydudi and update @DED . Please keep us posted on this; I’d just noticed it too.
I have the same problem
I have moved the the tracks to a new playlist and now they show bit of a drag but it works.
yes. making a new playlist and moving the tracks in it works, but with over 50 playlist to much work.
All tidal playlists are visible in volumio again. Thanks!
