Tidal Integration: Create Tidal Playlists from within Volumio UI
Hi!
The playlist management from within the Volumio UI is working great. All created playlists are synced through MyVolumio and can use music from multiple sources, and it is a feature I use a lot.
However, I was wondering if this could be further expanded to create/edit Tidal playlists with Tidal-only sources from the Volumio UI that can then be seen and reproduced from Tidal’s own app, for example, while on the go, or through Tidal Connect. Is that something that can be done or is even supported by Tidal’s API? Thanks for your input.
