Tidal Hi Res Stopped working
Hi…Volumio is v3.779 updated Friday. Tidal Hi and Medium Res then stopped working. Works on low res 320kb. Thought it was my Service Provider but proved their side is ok.
Can play Tidal Hi Res through the app…just not through Volumio
Any ideas?
The new software build successfully passed QA testing prior to release, and all audio resolutions for Tidal were played correctly during the process.
Could you please share more details about the platform and DAC you’re using?
Also, as a Premium user, you are entitled to dedicated support
You can follow up the request by rasing a support ticket HERE
Thank you
Best
Davide
Hi Davide…Thanks I will raise a support ticket on that link you provided. Is a Raspberry Pi 4 with a Hifiberry DAC HD
Its all been working perfectly fine, discovered it a day after the latest update was released
