Tidal Connect Stream Test – Raspberry Pi 4 vs Raspberry Pi 5
I’m new to Volumio and have been running a comparison test between two Raspberry Pis (Pi 4 and Pi 5) to evaluate how Tidal Connect handles audio streams through different hardware interfaces.
Setup:
• Pi 5 → Allo DigiOne
• Pi 4 → Audiophonics AES
• Both feed into a Bricasti M1se DAC for monitoring
I switch between the two setups to compare playback behavior and metadata.
When streaming from Tidal Connect (using the macOS app), the two devices don’t always receive the same signal format:
• Pi 4: 44.1 kHz / 16 bit / Audiophonics Digipi+AES
• Pi 5: 48 kHz / 24 bit / Allo DigiOne
I read :
• “A Bar Song (Tipsy)” – 44.1 kHz / 16 bit
• “A Bar Song (Tipsy)” – FLAC 48 kHz / 24 bit
The discrepancy also seems to appear depending on whether playback is controlled from the macOS Tidal app or directly from the browser via the local Volumio interface.Sometimes “Flac” appear. sometimes not .
This raises a few questions:
• Is Tidal Connect resampling based on the endpoint’s reported capabilities?
• Do the Pi 4 + Audiophonics AES and Pi 5 + Allo DigiOne report different supported sample rates?
• Could the iOS/macOS → Tidal Connect control path influence the stream format negotiation?
Thanks a lot for your help !
Phil
