Tidal Connect output setting
Hello together,
is there any chance to set Volumio as default output in the Tidal app?
Not a big thing, but for me it seems a little bit annoying to start the track first (only option my iPad) and then change to Volumio?
Maybe I didn’t check any hidden box?
Thanks and Regards,
Achim
That would be great. But it seems that Tidal’s default is always ‘‘This Device’’. Maybe you can send them your feature request?
As I mentioned: No great issue. And one can choose the detour via MConnect f.e.
Rgds
