Tidal Connect keeps stopping, Tidal through Volumio works fine
Hi All,
Tidal connect does not work for me. Everytime I try to use it, it stops completely. Tidal through Volumio works perfectly. Any help or ideas?
I am using a raspberry pi4, volumio version 2.878, and a smsl su-9 dac.
Below is the log. Any help would be much appreciated!
Simon
info: Pushing metadata
info: Unknown command: notifyPlaybackError
Hi Eastvansi,
thanks for your feedback.
Could you please provide the developers with the log volumio creates on the http://your.device.address/dev page? Just click on “send” there and post the result URL here.
Thanks a lot,
Robert
Hi Robert,
Here is the log http://logs.volumio.org/volumio/QunyDOn.html
Simon
I have also noticed that Volumio will not appear to play Tidal although the iPhone Tidal app appears to be playing. I need to stop the player and go back a song on the queue, and it will then start playing. This behavior appears to occur while the Tidal queue moves from one album to the next.
