Tidal Connect Hi-Res produces white noise on Allo Piano DAC (PCM512x)
:jigsaw: Summary
When using Tidal Connect (vtcs) on Volumio with an Allo Piano DAC + Kali reclocker, Hi-Res tracks (e.g. 24-bit / 44.1 kHz, 24-bit / 96 kHz) produce constant white noise / static, while 16-bit / 44.1 kHz tracks play correctly.
The same Hi-Res tracks play correctly when using Tidal integrated inside Volumio (MPD pipeline).
The issue is reproducible on both Raspberry Pi 3B and Raspberry Pi 4B, ruling out hardware limitations.
:desktop_computer: Environment
  • Volumio version: 4.119
  • Devices tested:
    • Raspberry Pi 3B
    • Raspberry Pi 4B (2GB)
  • DAC: Allo Piano DAC (PCM512x-based) + Allo Kali reclocker (GPIO I2S)
  • Output mode: I2S DAC enabled in Volumio
  • DAC driver:
    dtoverlay=allo-piano-dac-plus-pcm512x-audio
:headphones: Problem description
:heavy_check_mark: Works correctly:
  • Tidal Connect playback at:
    • 16-bit / 44.1 kHz (S16_LE)
  • Volumio Tidal plugin (web UI) playback:
    • 24-bit / 96 kHz (S24_LE)
    • 24-bit / 44.1 kHz (S24_LE)
    • and any track I play from tidal
:x: Fails (white noise / static):
    • 24-bit / 44.1 kHz
    • 24-bit / 96 kHz
:microscope: ALSA observations
During playback via Tidal Connect:
16-bit track:
format: S16_LE
rate: 44100
channels: 2
Hi-Res track (24-bit):
format: S24_LE
rate: 96000
channels: 2
access: MMAP_INTERLEAVED
Despite correct ALSA parameters and successful PCM device opening, audio output is only noise.
:bar_chart: CPU usage during issue
System load shows no saturation:
vtcs CPU usage ~10%
system idle ~70%+
load average ~0.01
Conclusion: not a performance issue
:repeat: Reproduction steps
  1. Install Volumio 4.119
  2. Configure:
    • Allo Piano DAC (PCM512x overlay)
    • I2S DAC enabled
  3. Enable Tidal Connect
  4. Play:
    • 16/44.1 track → OK
    • 24/44.1 or 24/96 track → white noise
Same behavior on:
  • Raspberry Pi 3B
  • Raspberry Pi 4B
:test_tube: Comparison with Volumio Tidal plugin
When playing the same Hi-Res tracks via Volumio Tidal integration (MPD):
  • Audio is perfect
  • 24-bit / 96 kHz works correctly
  • No noise
This strongly suggests the issue is specific to Tidal Connect (vtcs path).
:brain: Key observation
Tidal Connect (vtcs) opens ALSA device successfully:
PCM opened successfully
However:
  • audio is corrupted only in 24-bit mode
  • 16-bit playback is unaffected
  • issue is independent of Raspberry Pi version
:warning: Hypothesis
Possible causes:
1. PCM format handling bug in vtcs
  • Incorrect handling of S24_LE stream on PCM512x DACs
  • Possible mismatch in packed/unpacked 24-bit samples
2. ALSA direct path mismatch
  • Tidal Connect bypasses Volumio audio pipeline
  • Direct ALSA access differs from MPD route
3. PCM512x / Allo DAC driver interaction
  • DAC works correctly via MPD
  • Fails only when stream is provided by vtcs
:test_tube: Hardware/Software exclusions
  • Not Raspberry Pi performance related
  • Not power supply related
  • Not I2S wiring / hardware fault
  • Not DAC failure (works perfectly with MPD)
  • Not network issue
  • Not sample rate limitation (96 kHz is accepted)
:receipt: Conclusion
The issue appears to be a Tidal Connect (vtcs) compatibility problem with PCM512x-based DACs (Allo Piano) when handling 24-bit audio streams via ALSA direct output.
:pushpin: Request
Please verify:
  • vtcs PCM format handling for S24_LE streams
  • ALSA output path differences between MPD and Tidal Connect
  • Known issues with PCM512x / Allo Piano DACs
:scientist: Additional notes
This issue is:
  • 100% reproducible
  • independent of Raspberry Pi version
  • strictly related to Tidal Connect playback path
Matteo
simple and only solution:
resample to 32Bit and noise is gone
sometimes reading forum is more useful than AI suggestions
I am dealing with this issue since … I don’t even remember (years). And I tried every combination of parameters in the resampling section. Currently I have 32 bit/384KHz because is the only combination that works with some web radio.
Yes, I tried to explore using AI… at the end of the day I bought a RPi 4 to replace my RPi 3 with no success (thanks GPT…) so the most useful thing that AI did was the report I used to open this thread.
@Josh2000 do you have my same configuration and did you solved digital noise issue with Tidal Connect ? Or is there any thread I missed ? (I know you have same hardware because you were in the thread related to the kernel 6.6 issue I opened 2 years ago, but I do not know if you are using tidal connect)
I do have the same issue (on a raspberry pi3b with Piano 2 plus Kali reclocker), but somehow the white noise is gone when I use fusion dsp (without resampling)
