I have searched for this in the forums but didn’t find an answer:
I’m running Tidal Connect through an RPi4 and the Topping E30 DAC connected through USB. Volumio version is 2.882
The problem for me is that I can’t make the combination to play gaplessly. It’s not a big deal, but I’m nervous I can’t make it work
So, is there a way to make Tidal/Tidal Connect to play gaplessly on the RPi? If it’s important, I’m using a Samsung mobile phone as a controller.
Thanks,
Vlada
I have the same setup (RPi4 via USB to a Topping E30 DAC) and albums play gaplessly through Tidal Connect and through Tidal inside Volumio. Try Pink Floyd’s The Wall to test.
Thanks, it seams that it works: I’m listening to The Wall from Tidal through Bubble UPnP at the moment and it is gapless.
Will try the RPi/E30 combinatiom tomorrow - that combo is in the living room where my wife is watching the Eurovision Song Contest now with my daughter…
so, I’m banned from there…
Thanks again
Vlada
So, I’ve tried to get TIDAL Connect to gaplessly playback on my RPi/Topping E30 combination, using Volumio, but it does not work. Pauses are inserted between songs. Whatever I did, I couldn’t make it gapless.
It’s not like I’m gonna cancel my Volumio subscription over this, but it IS annoying and I know that gapless playback on Volumio should work.
Does anyone have any ideas regarding this?
Vlada
