I am having an issue where by random tracks of an album or even playlist in Tidal Connect just don’t play. The Volumio interface shows the track playing with no sound, but Tidal Connect has a spinning circle around the play button. This has just been happening over the past week. I am still on a Virtuoso account and had no issues running this system since the Volumio 3 update which I upgraded to as soon as it was available. I am using Volumio 3.179 and streaming from a MacBook Pro (Monterey) to Raspberry Pi 4B. Come to think of it the troubles started soon after the Monterey install. I use Wifi to connect to the Pi and USB from the Pi to a Peachtree Nova 150 amplifier.
I have restarted the Pi a dozen times and also reinstalled the OS several times with no luck.
Anyone having the same issue?
I am having the same problem. I have Volumio 3.198 running on a Raspberry Pi 4B with a HiFiBerry DAC2 Pro. I experience the problem when streaming from a MacBook Pro (macOS Monterey 12.0.1) and a Google Pixel 2 (Android 11).
For me it seems to be related to the particular track as some songs always refuse to play and others always play with no difficulty.
When it happens I see the below errors in the Volumio Test Player logs:
[2022-01-25 23:35:46.078] [tisoc] [error] [logger.cpp:25] [operation_curl.cpp:257] curl_easy_perform failed: Stream error in the HTTP/2 framing layer - HTTP/2 stream 0 was not closed cleanly: INTERNAL_ERROR (err 2)
[2022-01-25 23:35:46.079] [tisoc] [error] [logger.cpp:25] [http_stream_fetcher.cpp:162] Content-Range is missing from response!
[2022-01-25 23:35:46.420] [tisoc] [error] [logger.cpp:25] [operation_curl.cpp:257] curl_easy_perform failed: Stream error in the HTTP/2 framing layer - HTTP/2 stream 0 was not closed cleanly: INTERNAL_ERROR (err 2)
[2022-01-25 23:35:46.421] [tisoc] [error] [logger.cpp:25] [http_stream_fetcher.cpp:162] Content-Range is missing from response!
[2022-01-25 23:35:46.775] [tisoc] [error] [logger.cpp:25] [operation_curl.cpp:257] curl_easy_perform failed: Stream error in the HTTP/2 framing layer - HTTP/2 stream 0 was not closed cleanly: INTERNAL_ERROR (err 2)
[2022-01-25 23:35:46.775] [tisoc] [error] [logger.cpp:25] [http_stream_fetcher.cpp:162] Content-Range is missing from response!
[2022-01-25 23:35:46.780] [tisoc] [warning] [logger.cpp:22] [audio_worker.cpp:293] Max connection attempts reached!
info: Unknown command: notifyPlaybackError
