Tidal connect connection lost after pause
I tested Tidal connect today. After pause a track connection to volumio gets lost. You have to disable and anable the source to get Tidal connect back.
Also when this happens you hear a distorted sound htrough the speakers.
I use tidal app from windows to volumio. And tested it with andorid app. Same problem.
I found out today that the distortions occurs when you enable multi-room playback. When I pause a Tidal connect track I had distortion, when disabling multi-room no problems
