I am running volumio version 2.917 on a raspberry pi 4.
I am having problems where tidal connect stops being an option for an output source on my phone or laptop in the tidal app. Sometimes music will play and then randomly stop. Whem it happens, I am unable to login to volumio via the web browser using my raspberry pis ip address. A fresh install of Volumio always seems to fix the problem but then after a couple of days, it happens again.
I have included a log (http://logs.volumio.org/volumio/0bI5ohV.html).
Ok, I think I might have solved the problem. I was using a netgear powerline to connect the pi via ethernet-I think the problem was that I had it plugged into a powerstrip. According to netgear, this is not recommended and can cause dropouts
