TIDAL connect and song skipping
Hello.
I wish you all the best for the New Year.
I have a question about Tidal. Music plays smoothly in Volumio. But when they use TIDAL connect, the music sometimes cuts (skips). I have the quality set the same everywhere (highest possible). Internet problems?
Thanks for the advice and help.
Hi. Last time when I have this problem, it was from my internet provider. I wrote to tech help line about issue and they change my internet configuratin.
Thanks for the answer and advice. And you don’t know what configuration your provider has changed?
No. I had contact from provider after repair and techncian ask about issue. I said that everything is OK and it was all.
