TIDAL built-in client - cannot edit or delete playlist created via built-in client
Volumio Version:4.073
Hardware: Raspberry Pi3B+
DAC: Allo BOSS
A personal playlist TIDAL created via the VOLUMIO built-in TIDAL client (not via the native TIDAL app) cannot be removed (or edited). The playlisy initially synced to the TIDAL cloud, but removing it from the TIDAL cloud did not remove it from the VOLUMIO built-in TIDAL client. Trying to remove it in the VOLUMIO built-in TIDAL client gives a red pop-up error: Cannot remove list from favourites (see log below, no error in log)
info: Removing uri tidal://mymusic/playlists/az/3ae492ae-8eba-41c6-b5f1-bd7fe9f7e01e from favourites
info: CoreCommandRouter::executeOnPlugin: tidal , removeFromFavourites
I re-installed volumio from a downloaded image, but the playlist was still there. I assume it is stored in my VOLUMIO account and syncs after re-install and login.
Any help with removing the personal playlist from the VOLUMIO built-in TIDAL client would be appreciated.
