After apparently successful upgrade to 3.779 but now tidal and qobuz fail with “Error, no results”.
Same problem. Registration is ok but no results.
Same problem after updating my Rivo streamer to 3.779 during this afternoon… I restarted my device few times but error message still on the screen, and no Qobuz services are available. I hope this issue will be solved during the night…
Qobuz is back now.
Back for me too but not Bandcamp discover as yet.
Both Tidal and Qobuz are back up for me now.
Thank you, it is perfectly working now with Qobuz! Let’s the Music play again ![]()
I do have only a qobuz subscription and did get the same error. Did a log out and log in to Qobuz and the same again.
The UI states that I was logged in. So I did listen to YT music. After two hours qobuz was working as it should.
I discovered that not only it was a normal update to version 3.779. Additionally the firmware was updated from Ver. 0.3.3 to 0.3.4. This may explain the issues with the error.
I am using Rivo HW 2.1. Hope this helps or may be the explanation for occuring the error code.
By the way, with firmware 0.3.4 I did notice a sonical improvement over the entire listening area as well. My unit is connected to usb dac with lan and dac wired using supra cables.
Hello Olaf,
We discovered an issue on the network configuration on our infrastructure provider and we solved it yesterday evening
Thank you all for the patience!
Best
Davide
VOLUMIO TECH SUPPORT
Tidal is issuing this error on every song i like to play after upgrade to 3.779:
(Navigate to songs and so in is working fine, playing them not)
Failed to decode http://127.0.0.1:3245?data=tidal://song/198397671&soundQuality=HI_RES; got HTTP status 404
I have same problem at my new Rivo Plus:
Failed to decode
http://127.0.0.1:3245?data=tidal://song/27831866&soundQuality=HIGHEST_POSSIBLE; got HTTP status 404
[/quote]
System version: 3.779
Hardware revision: 1.0
Firmware version: 0.2.1
