thinkerboard + jlsounds xmos issues
Hi all,
i have a simple setup:
the only problem i have is this: after installing volumio and connecting the usb interface I got this:
402.369594] usb 1-1.1: USB disconnect, device number 35
[ 402.563194] usb 1-1: reset high-speed USB device number 32 using dwc2
[ 403.073159] usb 1-1.1: new high-speed USB device number 36 using dwc2
[ 403.174115] usb 1-1.1: New USB device found, idVendor=20b1, idProduct=2023
[ 403.180990] usb 1-1.1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 403.188304] usb 1-1.1: Product: JLsounds Hi-Rez Audio 2.0
[ 403.193705] usb 1-1.1: Manufacturer: JLsounds
[ 403.298645] usb 1-1.1: can’t set config #1, error -71
I have no other usb consumers so i have no clue what;s the issue.
Any ideas?
Thank you
