"There is no Internet connection"/volumio.local
I used Volumio on my RPi3 (Rpi3>amp>LS) for last 6 months with no problem, everything was set, everything worked - recently I came back from vacation (almost a month) and I couldn’t start Volumio from Chrome. The browser keeps show up that not working site with a little dino you can play with.
I tried to restart RPi3, I tried to make a new hotspot, even used LAN cable from the router - nothing works and I don’t know where the problem is. Could you help me with any tip, please? Thanks
PS: I think I used the newest possible Volumio version.
Does it work using the IP address rather than volumio.local/?
nope, tried that too.
Can you see the RPi as a connected device on your router?
nope :frowning:
Quickest thing would be to reflash, but if you want to investigate the reasons why then you need to connect a keyboard and monitor.
reflashed and set up new hotspot via LAN.
RESOLVED. thanks!
