Dear beloved volumioers!
Our forum board needed some love and we finally decided to tackle it and migrate to discourse!
We did our best to retain all old users and forum posts and to rearrange the thread structure a little bit.
Of course, the best part of this community is, well, you!
So let us know if you like the new community, what you think we can improve, if you have some ideas for new or restructured categories.
In short, tell us your feedbacks and ideas!
Enjoy!
This migration happened thanks the great Volumio Moderators team: ashthespy, gkkpch, balbuze, ian! Thanks guys, amazing feat!
I didn’t experience the old forum, so I can’t compare. In general I have found this forum to be a very useful resource and the people are quite helpful. Makes being new to Volumio much more manageable.
On the downside, I find the search feature to be pretty useless. I can do a google search that leads me to posts in the forum, but if I use the search function in the forum itself it returns nothing. Not sure why that would be.
With the old forum, I could use Google Translate to translate the whole page, now it doesn’t …
Quite uncomfortable for those of us who are lazy in English.
Saludos desde Chile, entre en el negocio, compre membresĂa anual. Sin embargo, al actualizar dejĂł de funcionar el PiFi DAC 2.0 (China). Les solicito orientaciĂłn para la devoluciĂłn de mi dinero o cĂłmo gestionar lan actualizaciĂłn de los controladores que permitan utilizar este DAC.
Es increĂble que no teniendo membresĂa y no actualizando el controlador todo era mejor (insĂłlito)
Hi, your DAC is not officially supported by Volumio (and therefore not tested).
The reason why it does not work anymore is probably because newer versions of the kernel did break it…
My suggestion to have the best possible experience is to stick to officially supported DACs where we do our best to support them.
There will be a new kernel update soon, which will maybe fix your issue, but I can’t say for sure since I don’t know this DAC…
Dear beloved volumio moderators team!
thank you so much for this new, much more comfortable and modern forum.
I like it. the only thing i’m missing right now is to edit older posts.
seems the option to edit is gone after some days of publishing.
