Hello, Firstly thank you so much for offering such an excellent player volumio!
I have updated to the latest version 2.692 [issued Thu Dec 19th 15:25:11 CET 2019],
and found that the file name does not synchronize with the playing file.
1)The playing symbol stays on the first song as well as the file name while it’s already the next song(the 2nd, 3rd,4th,5th… all the same, no change).
2)The file name is the 3rd one’s while the current playing file/song is the 2nd one.
This problem does not happen for all files, when I choose to play “cue” file, it happens always.
But when all the files are separate(no cue file), I choose to play all, I don’t have this problem, it’s ok.
And sometimes even though the current palying song has not been finished, it still jumps to the next song.
Or when I adjust the playing progress bar[to fast forward], the current file/song will stop and jump to the next one.
This problem just happens occasionally, not frequently.
I am not sure if I am the only one who have these problems, if anyone can give me some instructions to improve,
I will appreciate for that!
Thanks for your attention!
My devices: Raspberry Pi 3B+ —> DAC 1 HIFI
