The android app is appalling
(Nothing phone 3a)
Ive been putting up with this slow, sloppy, unresponsive app for ages. But just updated the to latest firmware update and now its even worse:
-The volume control doesn’t exist anymore, no matter what setting I change to use MPD or software controls it will not work. Even when I can find the slider it makes no difference at all, its set permanently at 100%. My amp has to be turned down to a 8:00 position or its too loud.
-Huge delays when playing or changing tracks in my Tidal playlist, it will also seemingly add tracks to the current playlist.
Absolutely hopeless.
Thinking of selling it and going back to local FLAC files using MediaMonkey.
Difficult to give advice without any details. Please say what you’re running Volumio on, which version of Volumio and which version of the Android app. Logs may also help.
Do you have the same issues using Volumio via a browser?
I use the Android app and it’s fast and reliable. Also with Tidal.
Browser is fine, but its not connected to the Rivo.
I’ll post logs and confirm Vs if I can - thanks for the reply
As a Rivo owner, you’re entitled to Premium Support.
Please create a support ticket here
Would you know if there’s a way to play via the Tidal app instead? Is this supported?
Your Rivo supports Tidal Connect.
How to use TIDAL Connect on Volumio? | Volumio
Before you give up on it, I’d try to narrow down where the problem is.
When you say the browser is fine, can you connect the browser directly to the Rivo and see whether the same problems happen there?
Also, a few things would help:
  • Which DAC/output are you using from the Rivo?
  • What is Mixer Type currently set to?
  • Does the delay happen with local files as well as Tidal?
  • Is Infinity Playback enabled? That can add related tracks to the queue automatically.
If the Rivo works normally through the web UI but badly through the app, that points strongly towards the Android app. If both behave the same way, it’s more likely something in the Rivo/update/output configuration.
Worth checking those before selling it, especially as the problem became worse immediately after the firmware update.
Thanks for the detailed reply pal.
I played around with turning some of the options off/on, installed another update and its back to working again.
Still no idea what the cause was.
Get Roon if you want the best experience, it’s very expensive though. You would hope this works properly on a rivo device vs a raspberry pi (which you can expect to be hit and miss sometimes). You could try Plex amp.
It’s much Better using Tidal app etc, or foobar if you are at the computer.. Keep things simple.
