The ability to skip forward or backwards 30 seconds?
I’m using Volumio to listen to podcasts. Is there a way to get buttons to skip forward/backward 30 seconds? Similar to what is possible in the iOS podcast app.
That function is currently not available as plugin.
If you know how to program, you can create your own script to do this.
Or you can use a IR or BT remote controller and add these command to one of the buttons. It will only skipp 10seconds:
volumio seek plus
volumio seek minus
