Been running Volumio 4.119 for the last week or so.
System installed on NVME (Samsung 128GB PM991a) on a Waveshare CM5-IO-BASE-B with 8GB CM5 lite and a Topping D10 USB Dac.
My usual plugins of GPIO Buttons, Rotary encoder II, Fusion DSP and Now Playing.
Ive had a few long sesions with it and It runs fine, snappy GUI. No glitches, No crashes or hangs etc. It just works ![]()
Even my Tap to add mod works with out any issues (which keeps the missus happy)
Well done Volumio development team.
The only minor issue I have come across is with one section of the GUI. “System settings”
If you use your screen in landscape then the four large buttons can still be activated in the area to the left of them… see pic. A little scary when scrolling on a touch screen and you tap the area to the left of factory reset, and it just jump straight into starting a facory reset.
